speedball3
- Dec 15, 2008
Hi everybody,
I have done quite a bit of searching for a solution, but have yet to find one that does the trick...hope you guys can figure it out!!
I have a 4.0L V6 94 Ranger that occasionally has trouble starting. The trouble is typically in the morning but has also happened when trying to return home from work.... but basically, it only happens on a cold engine. The starter cranks and cranks but the engine never turns over. It is cranking at a good speed too, so the battery doesn't seem to be low. Ambient temperature or humidity don't seem to make a difference... it happened in the winter and it happens now. Plus, I'm in San Diego, so winter means a low of 40F, if that. I've read the threads on having butane in the gasoline, but just yesterday I tried the cycling on/off trick for about half an hour and it didn't work (usually it seems to do the trick). About a year ago, the fuel pump was replaced... didn't help (plus dealer couldn't reproduce the problem). I have tried cleaning the IACV (didn't do much) and replacing the IACV (seems to have helped, but not cured it). Next on my list is cleaning the MAF sensor (I have felt slight hesitation when accelerating at WOT onto the freeway) and maybe replacing spark plugs (though I hear getting one of them out is a nightmare).
Other items of interest:
- Previously, when trying to start the engine, I have heard a hollow, metallic "ping" sound, usually within 30 seconds before or after the engine turns over
- Yesterday, I had a couple guys help me push start it, and it fired right up immediately...after a 1/2 hr of trying the on/off key cycle trick.
Anyway, I hope I have given enough information. Your help and knowledge are greatly appreciated!!
