94RangerGuy
I have a 1994 Ranger with ~195,000 miles. It seems that when the engine is under load (typically when climbing a hill in 5th gear or if cruising then I depress the pedal to accelerate when passing etc.) the engine will give a periodic hesitation (stutters kinda) - I notice this once it gets up to temperature. The problem will go away if I downshift to 4th gear where the RPMs are higher. I have had this problem with the truck twice before. The first was about 2 years ago (~160,000 miles). I replaced plugs and wires and the problem went away. Then about 6 months ago (~185,000 miles), again, I replaced plugs and the problem went completely away.
Any ideas? I was told told to change the EGR valve, but to be honest with you I can't even find it in my truck.
Thanks!
Thanks!
