Fuse is good?
Does the key chime still work?
Regular cab or super cab?
A 1994 still has pin switches in the door's front jam; it was '95 they went into the latch handle. Check the pin switch operation, and try spraying with contact cleaner or WD40 through the switch from outside. If you remove it to check the wire connections, pull the fuse then reinstall it after the switch is out (it switches +Positive, so it's easy to short out and pop the fuse when removing or installing). Once it's in your hand and a good fuse is reinstalled, you can check power in and power out of the pin switch.
There's also a diode for the dome light that's in the harness going to the cargo light; if it's blown the light switch won't turn on the dome but the door switches should still work.
