i have a 94 ranger 4x4 and i just got it aligned and i was wondering if the specs looked correct cause some of the specs aren't within the vehicle spec such as cross caster and front left camber.
And what did you bend in the front to make it pull?
Also, cross caster is not really important to have "in spec". Caster can have drastic effects on pull, and can be used to counter road crown, to make the vehicle seem to drive straighter on a crowned road (like you get in many rural areas). The side effect of that is that on a big highway with less crown it may seem to pull to the left.
For
