dave5688
- Mar 27, 2009
- Automatic
I have a 1994 ranger 4.0 automatic 4x4. It runs fine when cold. After running it about 10 minutes and it gets up to opperating temp, it developes a miss. I have found that when you remove plug wires from the coil pack, there is no change when removing the rear wire on the right side. There is good spark jumping to the wire. I believe this is my bad cylinder. I next removed the injector wire from this cylinder and there was no change. Could an injector fail when hot? Am I looking in the right direction?
