94 motor in a 89??
kx1254real
Alright so my indestructible danger ranger dropped a valve this week and i cant afford another car. I can get a motor from a 94 ranger with 180k miles for $200 but im not sure if it would be a direct bolt in for my 89. Does everything hook up the same or should i try to find an older motor? thanks guys.
use all of the accessories off of the '89 along with wiring and sensors, the crank sensor should be the same, you might have to change fuel rails, but should be a direct replacement.
