94 explorer mania swap
So, the auto computer is known to cause idle issues.
That said it also sounds like you have another issue. Vacuum leak, bad IAC, problem with the TPS, you’re gonna need to run some checks
I think I might be dumb as shit I just realized i used the thicker style gasket for the upper intake instead of the thin one, I had it from my ranger that might be my leak
That shouldn't matter as long as it's the same shape. I'm using a slightly thicker MLS head gasket to reduce compression and knock when using 87 octane.
