pzilla
- Apr 30, 2008
- Automatic
94 explorer brakes dragging??? any ideas?
i have several 94 eplorers and having an issue with my daily driver... ive replaced master cyl, lines, wheel cylenders, calipers, all brakes, rear hardware and drums/rotors. it seems to get less noticeable when i un-adjust the rear brakes so they are loose. it got so bad it ripped the backer plate off my axel on 1 side! wtf! also the abs no longer works and light comes on if they try to go off. i had a leaky axel seal on 1 side but i replaced both sides when i fixed the backer plate. it also seems the pressure gets applied only after moving forward a short distance at 1st, and stays applied til next drive or go in reverse... sometimes it locks the rear tires right solid. my poor limited slip is taking some abuse! any comments, ideas or help would be greatly appreciated. thanks for your time if you read this and have any feedback
