Johaco
- Feb 7, 2020
- Washington
- 3.0 V6
- Total Lift
- 0
- Total Drop
- 0
Hi, I'm having an issue and at a loss where to even begin.
I have 1994 b3000 manual 4wd. It's got ~80k miles on it. New clutch, oil, plugs, ignition coil, and wires about 2k ago. The only previously known issue is that the fuse for the turn signals blows regularly. Just trying to make sure I give as much info as possible.
Driving today, I began making making a left hand turn out of an intersection and it started moving, then quickly lunged to a stop. It would rev in every gear a seemed like it had resistance (kinda like a parking brake still on, but I couldn't overpower it), but wouldn't move forward. I tried to put it into 4wd and it still would not move. Finally tried reverse. Backed up a foot no problem. Went into first. It went forward a foot then seemed to lock up again. So I reversed carefully about 10 feet, went forward, and everything was fine. Carefully and slowly drove it the half mile home. Parked it. Tried forward and reverse and all seems to work. I'm stumped. I'm happy to research the actual repairs, but I just don't even know where to start. Failing drum brake? Parking brake cable? Transmission? I would love any suggestion as to where to begin as this is a confusing one for me. Thanks!
