94 & 96 4.0 auto trans interchangeable?
niterider
tewksbury, ma
from what i can see in the tech page both years should be a 4r55e? i found a rebuilt that i woul like to pick up. i believe that i'm losing my converter, front pump, or flywheel. i got 25k out of a separator plate gasket & shift repair kit and it still runs good. but to pull it apart again without just doing a trans swap seems like i'm just buying time.
No not at all. 94 is an A4LD and the 96 is an electronic A4LD.
thanks. i re-read that section and see that they designate both years of trannys "T". see how long for it to break so it doesn't go then fix it i guess.
