94 96 4.0 are they the same?
dman2121
Hello just wondering is the 4.0 from a 94 the same as a 96?
I have a 96 I need a motor for I found a 94 just wondering if it will swap or not
Yes, just swap the heads and block, bolt your '96 intake, exhaust, Cam sensor and oil pan/pump(if different) to it.
That way all your wiring will be the same
Well that's the problem I bought the truck with no engine in it and I found a 94 that runs I was going to buy for the motor and transmission out of it
1994 has an EEC-IV computer(OBD I), no Camshaft Sensor Synchronizer
1996 has an EEC-V computer(OBD II), with Camshaft Sensor Synchronizer
You could buy a 1996 Camshaft Sensor Synchronizer to put in the '94
Not sure about the connectors for the other sensors through, I think they should be the same.
Ok thanks for the help I'll keep looking for a 96 4.0 or go back to the plans of a 302
