1994 Ranger 4x4 4L, work truck, almost 300,000 km(Canadian), been a great work truck
Lost water pump about 18 months ago, I put a new one in and found I had coolant bubbling out of overflow tank and "that smell" in the exhaust.
Did a compression test and found one cylinder lower than the others.
Pulled the heads and one had a crack between the two valve seats, got a new head and sent both to a machine shop to resurface and pressure test, and new valve seals.
Put it all back together and it worked fine, for 9 months, then it started to mis-fire when cold, ran fine once warm.
Then it started to run hotter and was losing coolant, "that smell" again.
Compression test showed one cylinder was low, again, different side than last time.
Stripped the engine down to the heads and found one head bolt wasn't tight!!!???
I am getting older, but I don't think I could skip a head bolt, 4 times.
But it was not tight.
Pulled that head and put in a new gasket with new head bolts.
Engine was never overheated so I just cleaned up the head and block.
Put it back together and everything was fine.
9 months later, I am looking at the samething, started to mis-fire when cold, now bubbling coolant, and that exhaust smell.
But this time the compression test doesn't ID a cylinder.
I have
170
175
170
175
175
170
Spark plugs didn't help much either.
But as soon as you started the engine the coolant would start bubbling out with the radiator cap off, this was cold, closed thermostat.
I did test the block the first time, but just by using a straight edge and feeler guage, it didn't show any problems.
The timing of this is a puzzle as well, why the delay if there is a bad head, or block, or a "loose nut holding on to a wrench"(assembly issue).
I plan on taking the heads to the machine shop on Monday.
Maybe an exhaust port has a crack?
But is there enough back pressure in the exhaust to push coolant out at 15psi?
I have
170
175
170
175
175
170
