jprevat
Ok guys, im really hoping yall can help me out. I have an 89 B2 with the 2.9/A4LD stock setup.
I have a donor A4LD and T-case from a 94 Explorer I want to put in, but before I get ahead of myself I want to make sure it is a bolt in swap. I have the Explorer front drive shaft as well if that makes any difference.
I guess what I need to know is what will I need from each vehicle to make this work and is there any advantage to using the 4.0L t-case? If not then I will split them and use my 2.9 t-case.
Thank yall so much in advance!
