94' Ranger
- Jan 17, 2021
- Southern California
- 3.0 V6
- Tire Size
- 15in rims + Falken AT3
My voltage consistently fluctuates between ~12-16 volts at idle, I'm worried that this will eventually kill my battery.
I neatly stripped and re-did my battery top-posts and all connections to my alternator, no change. The alternator less than a month old and the battery is maybe 1 year old. I have a remanufactured Motorcraft alternator (Part# GL8719RM) in my truck and the battery is an Everstart 750cca battery.
My best guess would be either a bad/loose ground OR an exposed positive wire is intermittently touching ground somewhere in my charging system. Anyone know where I should be looking? I retightened every ground I could find and I've followed every wire connected to my batteries and was unable to find anything suspicious.
Perhaps if I were to introduce a solid external ground to different points on my charging system I could at least narrow down the search. Any ideas?
Thanks.
Thanks.
