alwaysFlOoReD
⭐Supporting Member
- Apr 13, 2009
- '06, '11
- 3.0L
- Automatic
This may be a dumb question, but what does the brake cleaner do? Get sucked in an combusted? Is that how you hear a difference?
Yes, it gets combusted. If the idle surges up in rpm then you've found a vacuum leak. Brakeleen is a mixture of mainly toluene and [IIRC] acetone and a few other chemicals. If that or propane gets sucked in then the idle changes, usually faster. Spray at all intake gasket surfaces, throttle body, and the tubing from the maf back to the throttle body, and any other place that could let air in where it's not wanted.
