motoman196
- Jun 28, 2008
- Automatic
I just purchased this truck and have been trying to work out the bugs. It had been sitting for four years due to a bad altenator and dead battery???I had the altenator rebuilt and bought a battery. Installed them on the truck and she fired right up. Had a pretty good hesitation on the way to its new home. I figured probably bad gas so I filled it up and put some injector cleaner in. The throttle position sensor was unplugged. So I called to find out why. He told me he was told it was bad and to unplug it for some reason. Anyway I replaced it and cleaned the AIC valve and throttle body, changed the oil stuck in a new pcv valve, and cleaned the MAF sensor. Still has the hesitation. Also since installing the new TPS sensor the truck wants to rev up while driving and pressing the clutch in to change gears. Sometimes while driving it will hold the speed almost like having cruise control. I have noticed while idleing in the driveway (which by the way it idles fine at startup ) if i rev the engine it will try to die when it comes back down to around idle. I also noticed that for some reason when it tries to die if I press the clutch in the rpm's smooth out and it returns to idle speed not even mashing the gas pedal. What the heck! Sorry so long. Any ideas of what could be causing these issues? Thanks in advance.
