- Mar 5, 2016
- Automatic
I know y'all don't know me as I'm a long time lurker here. I'm very appreciative of many of the postings on here that has helped me many times in the past. Forgive me for not posting an introduction thread, but I'm not much for small talk, I'd rather cut to the chase. Anyways...
I've got a 93 Ford Ranger (XLT I think) 4x4 4.0L Manual. I've needed to do a engine rebuild for sometime now, but I've been pushing the issue as long as I can as she's not my daily driver. As of late she has gotten bad about not starting up when she's hot. I''' cold start her just fine and then drive 20+ miles somewhere and she won't start until she cools off. If she hasn't completely cooled then it's a rough ride home. (I did just replace the fuel pump with a delphi.)
I just came across a surplus Ford Factory Motorcraft 4.0L Shortblock. However, the SB is for a 95-96 Ranger. I intend to purchase complete heads from ProMaxx (thoughts?). So here's the purpose for this post. What do I need to make this SB work in my truck? Will the covers/intake/oil pan/etc off of my 93 engine work on this 95 shortblock? I had already purchased lifters for my 93, will they work on this shortblock or any chance it'll come with them? Where should I go for head gaskets and bolts/studs?
I've got a Luk clutch kit and pressure plate coming, so I can replace my clutch when I do this swap. Anything else I should replace during this swap???
Here's my list of parts so far. Any and all input is greatly appreciated.
Haynes Repair Manual Ford Ranger Pick-ups 1993 thru 2011
Motorcraft 4.0 OHV Reman Crate Small Block 95-96 Ford Ranger
Fel-Pro Head Bolt Kits ES72794
Fel-Pro HS 9081 PT Cylinder Head Gasket Set
Fel-Pro CS 9724-1 Conversion Gasket Set
Fel-Pro 72515 Oil Pan Drain Plug Gasket
ARP 100-9909 Ultra Torque Assembly Lubricant - 1.69 oz. Fluid Squeeze Tube
Competition Cams 104 Engine Assembly Lube, 8 oz. Jar
COMP Cams Pro Cam Lube 153
COMP Cams High Energy Camshafts 49-410-8
ProMaxx Complete Head FOR625-59
Melling MR-927 Rocker Arm
Push Rods mpr471 Melling
90-00 Ford Aerostar Ranger Explorer Mazda 4.0L OHV 12V Lifters Lash Adjusters
M328 High Volume Oil Pump
Royal Purple Break-In Oil 11487
Royal Purple Extended Life Oil Filters 30-8A
Standard Motor Products PS240 Oil Pressure Switch
Auto Specialties Underdrive Crankshaft Pulleys 526400
Goodyear 4060850 Gatorback Poly V-Belt (BB16)
Davis Unified Ignition Screamin' Demon Coils 31738
Motorcraft Platinum Spark Plugs AGSF42FM
Motorcraft Spark Plug Wire Sets FOPZ12259J
BBK 1580 66mm Throttle Body for Ford Ranger, Explorer 4.0L
C&L 73mm Mass Air Meter / Sender Housing 19lb Injectors
Blackhawk Intake Tube 27599TK
K&N RE-0950 High Performance Universal Air Filter
Spectre Performance 9541 Black 3.5"-3" Coupler/Reducer
Spectre Performance 95411 Black 3.5" x 3" EPDM Coupler/Reducer
Cambridge SAE Size 56 Worm Gear Hose Clamps, 10 pcs/Box. 1/2" Band Size, Min Dia 3-1/16", Max Dia 4" Stainless Steel
Uni Filter UP-104 5/8" Clamp-On Breather
Pace Setter 70-1170 Black Exhaust Header
Percy's (310068) 8mm-1.25 x 25mm Vibe-Lock Black Oxide Bolt Kit, Pack of 12
NGK 22503 Oxygen Sensor - NGK/NTK Packaging
J.W. Winco 906-ST-M22X1.5-GPC DIN906 Threaded Plug
FORD 4.6 5.0 5.4 MUSTANG GT / F-150 19 LB # POUND FUEL INJECTORS SET 8 USCAR OEM
GooDeal 8pcs Fuel Injector Adapter Kit for EV1 to USCAR EV6 & EV14 Chevy LS1 LS2 LS3
Motorcraft CM4713 Fuel Injection Pressure Regulator
K&N PF-2200 Fuel Filter
Delphi HP10141 Hanger Pump Assembly
Summit Truepart Select Replacement Starters 3240N
Engine Coolant Water Outlet 4 Seasons 85668 fits 91-00 Ford Explorer 4.0L-V6 35mm vs 32mm Hose required
JET 10142 Thermostat
Delphi TS10001 Engine Coolant Temperature Sensor
Volvo 2-SPD FAN RELAY and 2 Speed Fan
Upgr8 Aluminum Water Temperature Sensor Adapter (34MM, Black)
High-Speed Steel Hand Threading Tap, Uncoated (Bright) Finish, Round with Square End Shank, Bottoming Chamfer, M14 x 1.5 Size
URO Parts 61 31 8 361 787 Water Temperature Switch
BMW Collant Sensor Wire 164060
BMW Collant Sensor Ground Wire 164061
BMW Collant Sensor Wire housing 164509
Gates 38134 Belt Tensioner Assembly
Motorcraft WPT361 Pigtail
Motorcraft WPT237 Fuel Tank Connector
Genuine Ford Fluid XT-1-QF Type-F Automatic Transmission and Power Steering Fluid - 1 Quart
Royal Purple 01512 Synchromax High Performance Synthetic Manual Transmission Fluid - 1 qt.
LuK LFW156 Flywheel
LuK 07-096 Clutch Set
Slave Cylinder
Dorman 917-551 Shifter Rebuild Kit
Questions:
1. Valve Springs - With this Comp Cam can I stick with the stock springs or do I need to upgrade to the Comp 988 Dual Valve Springs?
2. Starter - Should I replace it now? If so with what brand?
3. Anything not on the list that I should replace while I'm doing the engine swap?
4. Lifters - I had already purchased lifters for my 93, will they work on this shortblock or any chance it'll come with them?
5. Wiring - Does anyone have a wiring diagram for my truck with wire size called out? I'd like to rewire my engine section while I'm at it, but prices on battery harnesses and what not for my truck are ridiculous.
Thanks in advance for any advice.
LuK LFW156 Flywheel
Slave Cylinder
Questions:
