93 Ranger weak parking brake after new drums and shoes...cables next?
xdepredatex
Forum Member
Colorado Springs
CO - USA
Vehicle
Drive
As the title states just replaced my 9in drums, shoes, and hardware on my 93 Ranger hoping to solve my weak/useless parking brake. When I initially looked the shoes were worn incredibly thin so I figured replacing them would fix it, but unfortunately it hasn't.
After installing the new shoes and hardware I adjusted the shoes so that there's a slight friction when putting the drums on. Before putting on the drum I could see the drums actuating under normal braking and engaging the parking brake.
Pretty confused so I'm assuming the next step would be parking cables, right? I also am curious what wheelbase length I should order. It's a reg cab with a 6ft bed so I'm assuming 108"?
They might just need a little more adjustment. Plus, the shoes may need to wear in to exactly match the drum diameter. If they work, but are just weak, I would give them time to wear in. Plus, every time you back up and brake to a stop, the self-adjusters should actuate and adjust them.
If you have oversized tires, they may not work as well, especially the 9” drums.
The replacement brake cable is a little thicker than the original and stronger. One person can change it. You start under the drivers seat. Fish the pedal end up thru the floor and hook it in to the pedal assembly. From this point on, you need to keep the cable tight till you hook it to the other end. There is a spring in front of the left rear wheel, that sometimes gets lost if it is driven with it broken. Your spring might be gone.
