93 Ranger Transmission cooler lines help needed
Kram
Can someone point to a place where i can buy the complete upper and lower OEM type transmission cooler lines for a 93 Ranger 4.0 2wd Extra cab
If your local parts store can't get them and your Ford dealer also can't get them, you're probably out of luck. Your choices are either junkyard or make your own. Your lines should be either 5/16s or 3/8. You can buy straight lengths of 5/16 and 3/8 brake line at a parts store. Just bend them yourself and join them together with the appropriate unions.
