PtownBubba
- Jan 15, 2015
- Automatic
Timing belt broke, so timing was lost. I put the Cam on it's TDC mark, [ I assume both valves closed ] and Crank on it's TDC mark [piston at top of stroke ], so at that point I need to have a spark to cylinder one.
Passenger side plug wire has spark, but motor will not start.
This motor is a 2.3L,,,,,,no teeth on backside of harmonic balancer, there is a crank sensor, with some rings-er-strips on harm. balancer
There is no dist. two coil packs, it is a 4cyl. / 8 spark plug motor.
Passenger side plugs do the heavy lifting, or makes the motor run,,,, driver side plugs fire,, more or less on exhaust stroke to burn off excess fuel,,,, left side plugs are for emission control stuff.
Left side spark plugs do not spark when turning motor over,,,they spark only after motor is running, again at a different time then the right side plugs.
Anything I can find on "this-year" 2.3L motor, says nothing about the third gear / oil-pump pulley having to be aligned with hash marks,,,, all it does is run the oil pump, so pulley position has no influence, on timing.
I assume the cam gear mark points to that lil' hash mark [ 5 o'clock ] on inner cover. What step am I missing,,, both crank and cam on TDC, have spark to plugs this is suppose to be a clearance motor, so valves should have survived the broken belt,,,, ???????????? What the,,,, is the next test ??
The Ford engineers must have designed this motor on Jan 2nd,,,,,,,,,,,, after a wild party,,,,,,,,,,,,,
I am told the 8 spark plug motor was soon dropped,,,,
