93 ranger oil send unit location
johnnycash
Hi ranger folks. 93 splash 3.0 4x4 automatic trans...can someone tell me the oil sending unit location? Thanks!!!
Oil pressure sender is on the passenger side, rear of block just below the head, pointed up. Single wire just pushed on the stud. It's a real PITA to get to. I accessed it from below and did most of the work without seeing it. I got some fittings and a hose and remote located an aftermarket pressure sensor with real gauge on my dash. I'll get a link and add it here in a minute so you can see what I did.
Here is the best picture I have at the moment. I mounted the sensor (inside yellow circle) to a bracket that is fastened under the front end of the coil.
Thanks. I gave up on guessing and feeling for it. Your help is appreciated. Thx. Jc
