Jwar2
- Nov 16, 2014
Hi I'm new to the group I've been searching the forums and have come to a dead end. I have a 93 ranger 2.3 manual trans I am not getting any fire to the intake side plugs, also the fuel pump only runs for a couple seconds when key is turned on and that's it. If I jump the fp relay the truck will start but only run on the exhaust side plugs. I am getting injector pulse. I have replaced the crank sensor with a new one and swaped the icm with one from the junkyard I have removed the pcm and checked for any burnt spots but wasn't any. Also the cel comes on with key and stays on while cranking which from what I have read means it's not getting crank signal. I'm stumped at this point any help is much appreciated
