boneyard360
- Dec 28, 2008
Ok I will try to do my best to explain all this. About 3 years ago my ranger started blowing only cold air in the winter. I had the thermostat replaced and everything was great again. Now just this month same problem started again on cold days my truck does not heat up at all. Its not a problem of blowing air cause it does that, also I can change from defrost/panel etc.... with no problem the air redirects fine. So after doing some research I was thinking it was the heater core. So I let the truck run and checked the hoses going into the heater core and the one closet to the driver side was always colder so I thought that was the problem,but I then noticed that my engine was not even getting warm so I was like wait a min that is a problem like the thermostat is stuck open but that cant be because I just replaced that a few years back(yes I do understand it could have went bad just not assuming that). So back to the heater core....well on days that its not so cold I was getting heat blowing in the truck like nothing was wrong so I checked the hoses to the heater core again and they were both hot. So I figured its not the heater core cause if that was bad I wouldn't get heat at all. It wouldn't matter if it was a warm day or a cold day. So right now I have ruled out the heater core as the problem, so I decided to a flush and change the coolant. Ran prestone flush and added new coolant and engine was still running cold so decided to just change the thermostat. So now here is were I stand and need help. Like I just said I did a flush and fill this weekend changed the thermostat, burped the system and the engine is still not warming up to "normal" and it still blows lukewarm air(sometimes on warmer days it does blow warm air while driving but when at a red light gets cold again). I also noticed that my heater core hoses are hot and the top radiator hose and the top of the radiator are hot while the bottom hose and bottom radiator is cold(is this normal on a 93 ranger)should the bottom hose and radiator stay cold?. So I ask could it still be a blockage or maybe the water pump(if that was bad I would think the engine would over heat, its not its running cold). Or does it still sound like a thermostat/heater core problem....or am I way off base and it sounds like something else. Its just got me confused cause as soon as I think its one problem another symptom rules that out...... sorry for such along post and for probably confusing anyone who reads this I just want to get all the details in 1 post. Thanks for reading.(wow time for a beer)
