93 ranger door panel removal?
That Baker Guy
mississippi
i have a 93 ranger xlt super cab, and i need to replace the factory speakers in the front door panels because they are completely useless at this point, i tried to take the door panel off today and got all the screws out and the electronic buttons popped off but i couldnt pop the face off, and i didnt want to get rough and break the darn thing so i stopped, any ideas?
If you got all the screws out you just have to pull up on it. My 94 has a screw in the armrest that i didn't see the first time I tried to take the panel off.
i got a diagram/instructions from autozone.com and it didnt say anything about pulling up, i feel like an idiot for not trying that. thanks
They all pull up on the rangers trust me ive got a 1994 xlt super cab and a 1998 reg cab dont have to take the electronics out either untill after you pull off the door panel
well i have a 93 and there are three screws one by the mirror, one in the arm rest, and one at the bottom left corner of it, and then you need a T25 torx head for the window crank to come off after that you can just lift it up and off. unless you have anything power then you will lift the panel up and unplug the wires then you can get to the 6x8
speaker
u have to take out the switches panels for the power stuff just gently pull it from the door handle then behind that is a screw, remove it and pull the door panel up, to remove the power panel, u can inster a rally thin plain screw driver in the edge fo it to open it up a bit
you can also use an allen wrench to get the torx screw out of the window crank
