93 ranger 4.0 coolant boiling???
py350
My 93 ranger's coolant is boiling I have changed the fan clutch and t-stat and the water pump and radiator. The truck doesnt over heat but when driving for a long time and I park truck and shut it off you can hear it boiling. Maybe air in the system? or a head gasket issue? any input would be great thx...:icon_confused:
what exactly is going on? is the truck getting hot? is it spitting fluid out of the overflow resivoir? or are you just hearing a boiling sound?
Sometimes I hear what sounds like a boiling sound when I turn off the truck, but it is just fluid gurgling in the AC system.
same issue here. Never overheats or leaks, just gurgles.
when driving for long periods like on the hwy and then parking it will be gurgling and boiling out a little of of the resiviour and no, I havent done the rad. cap yet but ill try it today! :)
trk doesnt get hot according the gauge speakin of gauges on the temp gauge as long as it stays in the normal part between the C and H its a good temp right?
Think I found the problem... I felt the radiator and the top is hot but the bottom is really cold so I think the radiator is clogged or air in the system...
