93 ranger 4.0 auto to manual swap transmission wiring
North Idaho 5.oh
5+ Year Member
Idaho
I can’t seem to find much info on the wiring side of things….
What I have is a 1993 Ranger 4.0 4x4 and wouldn’t you know it, the A4LD transmission quit. I swapped a manual transmission in it from a 2002 or 2003 (can’t remember).
Well she runs and drives just fine but the reverse lights don’t work. The brake lights and the turn signal lights work as well. PCM was swapped and the clutch pedal switch is installed. My question(s) is, is the reverse sensor different from 94 to 03? They look exactly the same side by side. Next question is if someone has a 1993 ranger A4LD to 2003 M5OD swap harness diagram with pics ?
  • 93 ranger 4.0 auto to manual swap transmission wiring
Hey @North Idaho 5.oh
I'm just a novice around here. And therefore I don't know a lot.
However.
Have you tried looking on eBay for a Haynes or Chilton manual for your year and make truck.
I'm sure they will have all the wiring diagrams for both the manual and the automatic transmission in them.
You could then compare and make your own wiring diagram.
I did a quick look on eBay real fast.
Here what I found:
I hope this helps.
Good luck brother.
Your welcome brother.
I'm glad to try and be of help.
Hopefully you can now enjoy your truck.
Thanks for letting us know you figured out what was wrong and what the problem was.
