I can’t seem to find much info on the wiring side of things….
What I have is a 1993 Ranger 4.0 4x4 and wouldn’t you know it, the A4LD transmission quit. I swapped a manual transmission in it from a 2002 or 2003 (can’t remember).
Well she runs and drives just fine but the reverse lights don’t work. The brake lights and the turn signal lights work as well. PCM was swapped and the clutch pedal switch is installed. My question(s) is, is the reverse sensor different from 94 to 03? They look exactly the same side by side. Next question is if someone has a 1993 ranger A4LD to 2003 M5OD swap harness diagram with pics ?
