ccaissie
- Aug 10, 2016
I see an earlier 2019 thread where the smaller rear bushing was way too loose in the front spring eye, but this is the correct bushing...Here, the spring opening is just too rusted/worn and after grinding the rust out, the hole is like .020" too big.
Slips in & out with no resistance.
Best fix? JAM some shim stock in there? JB Weld? (I know JB softens with heat so a future removal is easy...) .
Shim AND JB Weld?
My plan is to roughen up the outside shell of the new bushing and JB Weld it in with a shim driven in for good measure. Worst case, it fails and rattles, and because I have a new hanger and bolt, a removal would be MUCH easier than the rusty nightmare I had to get this thing apart.
I could run a bead of weld inside the spring, then grind until it needs to be driven in.....nah. That's plan B 2 in 2028.
Shim AND JB Weld?
