Welcome to TRS
1993 4.0l Ranger
Watch the CEL(check engine light)
It should come on with key on, this means the computer has powered up, no CEL = no start
Try to start engine, CEL should go OFF as soon as starter motor starts to spin the engine, this means there is a good timing signal from crank sensor so spark and fuel should start, if CEL stays on then No Timing Signal and no start
50/50 test
Spray fuel into the intake and try to start engine
If it starts, runs and dies then spark is OK, fuel delivery is the issue
If it doesn't fire or start then spark is the issue
This is just an easy and for sure way to confirm spark(timing) or fuel issue on ANY gasoline engine
Fuel pressure doesn't mean fuel IN the engine
Spark testers don't always work well with Waste Spark systems
If no CEL key on, check PCM Relay, and EEC Fuse, both shown on diagram below
If CEL stays on when cranking engine then check Crank sensor, it is on lower front of engine behind crank pulley, passenger side
1993 4.0l uses an EDIS-6 spark module, never read of one failing on its own, gets its 12volts from ignition switch, on the same wire as coil pack, so test the Red wire on the 4 wire connector on coil pack to see if it has 12v with key on
