slycer2002
Hi, my wife has a 1993 Camaro 3.4L, and we've recently run into an issue. Please bear with me as I have not had ANY time at all to take the wheel off and see exactly what the problem is. I can tell you that the rubber hose that runs forward from the junction block in the rear and connects to the line coming from the front of the vehicle is spraying hydraulic fluid. Whether the fluid is coming from that hose, or it is just running down it from a leak elsewhere is what I am not sure of. My question is this: Do any of you know if this year Camaro had issues with the rear hydraulics, or if we just got lucky? I will post more info tomorrow after I get the car torn down to see what the exact issue is. By the way, in case you couldn't tell from the fact the car is only a V6, we have rear drum brakes.
Thanks in advance, and sorry for the sketchy information.
