just4today
- Feb 15, 2009
I have recently acquired 93` Ranger 4.0,5spd. Truck has not run for awhile . So , i cleaned and gapped plugs , installed used starter , drained coolant , cleaned reservoir , pulled t-stat , refill w/ water and oil change . The oil was dirty but not contaminated . So , truck runs - sounds good,slight tick, no knocking or smoke wagon .
I go in town buy thermostat and install it and add about 1 - 1 1/2 quart coolant . Truck starts right up , heater is on high and blowing hot , gauge is showing about half , then after just a few minutes the reservoir starts overflowing probably a gallon or so .
To run w/o t-stat i simply installed rubber seal w/o mechanism . Installing new one i cleaned both surfaces and placed spring side towards motor .
Any thoughts on what this is ? Thanks .
