Trfsrfr
- May 27, 2013
I'm trying to diagnose a 93 with a 3.0 that just started running very poorly while cruising.
No Check Engine Light.
I'm fairly certain it has recently new plugs, wires, cap, rotor, but am unsure of the coil.
While cranking it over today with the distributor wire off, I watched it spark to its mounting bolt.
Is this normal and a sign of a good coil?
Or should it not have sparked at all and this is suspect?
The engine rev's and accelerates today, but very poorly and misses a lot.
Yesterday when it happened while driving home, it barely made it.
Tried a new fuel pump, but that isn't it, although it does rev now.
Thanks-
Thanks-
