Some bosch stuff sucks, but they're usually the best you'll find at an aftermarket parts store. If you go through ford you pay double probably though.
I wanted to test and see if my O2 sensor was working properly.
Have had trouble with high NOx. Engine does not have EGR valve. I wanted to measure the output with a voltmeter.
What wire do you monitor for that? It has 4 wires coming out of it. 2 white wires (preheater?), a black wire and a gray wire.
Its a 94 with over 200K on it and so far as I know the O2 sensors have never been changed (or even cleaned). Bought vehicle new.
Many thanks.
High NOx is my problem. I was told that an underperforming O2 sensor will make it run rich thereby creating a high NOx problem.
I found elsewhere on the net it said black was the signal wire. But it makes sense that might be ground.
I have an analog voltmeter which should give faster response times than a digital.
Now, to change them do you cut the wires and splice? Looks like the connector is between the heads and the firewall and is difficult to get to.
Or do you unscrew the sensor (coiling up the wires) and then unplug after you've got it out of the pipe?
Thanks again.
