I don't see why not.
Check that you have a distributor hole and there is a gear inside on the oil pump shaft.
If you don't have that then I wouldn't bother, you would need a new engine, well an old "new" engine.
If you do then you can get distributors with points and the intake from an older 2.3l.
2 barrel weber is a popular carb
You will need to change the fuel tank set up for lower pressure.
Won't need the computer, don't think it runs much besides the EFI system on the '93.
Oil pressure, engine temp, battery light/gauge and fuel gauge are all on there own systems.
Still have a speedo cable on the '93 not VSS.
tach would need to be rewired, maybe, might work fine from a coil.
If you have an automatic I am not sure if computer is needed in that year, if manual then for sure not needed.
I myself find EFI and DIS better than points or HEI, and a carb.
I grew up with points and carbs and am very comfortable working on them, but like the new systems better.
A $20 volt/ohm meter is about the only thing I need to find out whats wrong with the new systems.
The CEL(check engine light) is nice as well, and it doesn't mean a sensor is bad, it means a sensor has sent data to the computer that the computer thinks you should look at.
Engine is Lean or engine is rich, or EGR is not right, very cool stuff that OBD.
Beats the heck of of sniffing an exhaust pipe to see if it's rich or lean, lol.
Check sensors first with a meter, never replace on spec, a sensor is usually "telling" you there is a problem, not that the sensor is the problem.
It would be like replacing the exhaust pipe because you were getting blackish smoke from it, carb is running rich, replacing exhaust pipe would be a waste of money
I know that's simplified, but example is correct, find the problem not the symptom.
