frdrks
- May 2, 2013
- Automatic
Hey everyone, my first time posting here.
I have a problem with my 92 ranger passing smog. (California)
I took it in for the first test and it passed all the tests except the NOx levels at both 15 and 25mph. The other readings were great, way below the limit.
I know this year model is not equipped with a EGR. I fixed a couple small vacuum lines that connect to the air filter box and some small lone canister up near the firewall. I ran an entire bottle of this "Guaranteed to Pass" solution in a full tank of gas. Got the truck warmed up and took it for a 2nd test. Failed again with almost identical results.
I started to suspect the catalytic converter. I took the converter out and inspected it, none of the meshes/screens are broken and nothing is loose inside. Im pretty sure its the original CAT that came with the truck in 92. Im a little lost of what to try next, i'd buy the CAT but worried ill just waste the money being that it might not be the problem. No check engine codes either. Truck has 140,xxx miles.
An issue i ran into 4-5 months back, when starting the engine in the morning when its cold out i can easily take off without warming up (even tho i still do). However, during the day if the engine is cold and i try to take off without warming up, it would bog and even died on me before. When it died i had to wait 10 minutes before i could get it to start again. Oddly enough it seems to have stopped. However, it still drives very sluggish. I can floor it sometimes and get very little response. Can the CAT still be defective even if it visually looks okay? No sign of blockage and i can see light come through. My exhaust tailpipe and muffler did rust/rot off a while back about 4 feet from the cat.
Test Results
15mph
CO2: 14.30
O2: 0.00
HX Max: 124, Ave: 37, Meas: 12
CO: Max: 0.75, Ave: 0.14, Meas: 0.18
NO: Max: 1020, Ave: 290, Meas: 1424
25mph
CO2: 14.19
O2: 0.00
HX Max: 104, Ave: 28, Meas: 0
CO: Max: 0.95, Ave: 0.13, Meas: 0.06
NO: Max: 880, Ave: 243, Meas: 1480
Test Results
15mph
CO2: 14.30
O2: 0.00
25mph
CO2: 14.19
O2: 0.00
