92 ranger 3.0 sway bar bushing help
Bloodlet
Ct
I measured the front sway bar in my truck. It comes in at .92 inches wich is about 15/16 (.9375) and the bushings are 3.5 inches from top to bottom. The bushing DEFINITELY need too be replaced but I cannot find any with the exact dimensions that I measured. Anyone have any ideas/experience?
Rockauto has a 23mm listed. Close enough?
SKP SK8689RA
Front To Frame; 22mm Or 23mm Sway Bar Diameter
could be! a little tight has to better than a little loose! Thanks.
