- Apr 14, 2008
- Age
- 35
- Gansevoort, NY
- Automatic
So I have a 92 3.0 Auto 2WD Supercab with 70k/Miles, in front of me. Drove perfectly fine one day. No start the next morning. KOEO jump test shows a 1-1-1 [all clear]. You can hit the starter, it will attempt to start but as soon as you let off the key it shuts off. Fuel pump is brand new [Delphi] and pulls 40psi, holds 40psi for awhile, not seeming like a fuel issue. Compression numbers are around 160 across the board. Spark is sparking, Ignition control module replaced with new Fomoco unit. Unplugging MAF does nothing. Any leads in diagnostic flow would be greatly appreciated.
