92 expo
509lifted
Firefighter
chelan washington
since the leaf springs are under the axle can i just pull the blocks to give it some lift or do i gotta do a flip kit?
are there even blocks between the leaf and axle? I've never seen an explorer with blocks there UNLESS it had a lowering kit on it.
you do realize that a flip kit is gonna net you like 5" of lift right?
Is the Explorer lowered? Cause are no blocks between the leafs and axle.
its not lowered but there are blocks between the leafs and axle on mine
ok so i should be able to take the blocks out and it will be fine right?
chrwilkins it does have blocks unless the spring perches are that big cause it looks like its a 2 inch block
well does it look like a block or a spring perch they are pretty distinguishable between eachother
just post a pic of it.
as of right now i dont have a camera but i messaged the guy and he said his brother put stock ranger blocks under the back with longer u bolt so i should be able to get shorter u bolts and remove the blocks since that is how it was stock
yes. take out the block.. see if the u-bolts will tighten down, if not get shorter ones.
