92 2.3L Check Engine Light - Codes 327, 328, 334
pad2383
20+ Year Member
Hi,
I've got a 1992 Ford Ranger 2.3L with about 240,000 miles on it. The check engine light started blinking on and off pretty regularly so I pulled the OBD1 continuous memory codes and came up with this.
327 - EVP/EPT circuit below minimum voltage
328 - EGR closed valve voltage lower than expected
334 - EGR closed valve voltage high
I can't say these codes mean a whole lot to me besides I've got issues with my EGR valve or the EGR valve position sensor.
I replaced the MAP sensor/EGR vacuum solenoid less than two years ago, so that ought to be fine.
I figured I would post and see if anyone had insight into these codes or the combination of them together. Any tips for diagnosing/fixing it? I was thinking I'd start by replacing the EVP sensor. They're not too pricey.
Pad
Put a vacuum hose on the EGR valve and suck on it. If you can draw air the EGR is bad.
Just in case it might help someone else in the same situation, I put a new EVP (EGR position sensor) in and that fixed up the problem. No more check engine light and running great.
