91 ranger with 91 5.0 swap misfire
stranger_5oh
I have a ghost misfire living in my engine... I've been having this problem for quite a while but I've changed plugs/wires, MAF and TPS... I have also checked firing order, timing @ 10 degrees adv, no vacuum leaks, 42psi fuel pressure, got good spark and went as far as to lap the valves to rule that out but when I drive the truck it cuts out like it's missing... I have another cap and rotar I plan on putting on and testing voltage to the TPS... Other than that I'm out of ideas
Sent from my SM-G900R4 using Tapatalk
