Fairlaniac
- Dec 8, 2007
- Age
- 65
- Denver, PA
- 3.0 V6
The rear in my ’91 Ranger (beater truck) is vibrating and in need of repair or replacement. I’ve only had this truck since 12/12 so I don’t know much history. The pinion bearing and seal are shot as it leaks and I can grab the driveshaft and move the pinion all around with a 1/16th or more of movement in any direction. The axles rotate with 5-10 degrees of slop and when I put the truck on jack stands and run it in gear there are all kinds of snap-crackle-pop sounds. I’m afraid I’ll have a ton of cash in it to fix everything so I’m looking at used assemblies. It’s easy to figure a 3.73 w/ 10” brakes from a ’92 – down will fit but will any others such as 8.8 rears fit easily? Whatever pops up first I’ll probably buy. So my questions is, when looking at a complete used assembly. Which model of vehicles should I look at? I recall something about the 8.8 pinion flange is larger than the 7.5 so does it require a different pinion yoke? I’m not going nutso on this and putting an Explorer disc brake rear on. Just a simple swap in and out with minor mods is ok with me.
Thanks,
Thanks,
