wagonerkl
- Feb 3, 2011
- Automatic
I just did a clutch change on my sister's '91 4X4. We put in a brand new clutch slave, throw out bearing, clutch and pressure plate. Everything is back together but the clutch line from the master to the slave will not click into place.
I have tried as much force as I can muster and it just will not go in. There does not seem to be any obstruction or any damage or deformation of the line. Yes, I pulled out the little plastic protector plug on the clutch side. Also replaced the o-ring with the one provided in the clutch kit and the little white plastic sleeve.
I am afraid I will break something if I try and pry it in. Has anyone else ever had this problem? Am I missing something? Help please. Thank you.
