91 ranger 4cyl 5speed 2wd
goodoleboyz250
Will a trans out of a 98 with the same specs fit this truck..guy that I'm geting it from said it would..called junk yard and they said 97 was the latest..checked the guide and it says 88 up..
Sent from my SCH-I405 using Tapatalk 2
it will technically fit the engine and drive shaft, but the clutch disconnect will probably be slightly different (changed in '92) and there won't be a place to plug in your speedometer cable
