'91 power dist. block sounds like a geiger counter?
Sound like a relay failing or a bad connection powering the relay.
Under that power box are 3 relays, EEC relay, Fuel pump relay and WOT(wide-open-throttle) relay.
Good picture here: http://www.explorerforum.com/forums/showthread.php?t=187330
#5 post
Green base is Fuel pump
Brown base is EEC(computer)
Black Base is WOT
They are all the same type of relay so can be swapped
I say bad relay. Pop the cover and put your finger on each relay. You should feel one going crazy and the others will not be moving. Or they all could be... but at least one is bad. They're about $12 each at orielly's.
