Code_Kid
- Jun 20, 2008
ok just got the truck 166,000 miles.
ok was pulling out of mcdonalds drive threw didnt give the truck enough gas and boom i killed it, stupid me.
went to start it and nothin i noticed i did not have it in neutrol so i put it in neutrol turned the key and nothin....
so i had to push the truck out of the way started to have a good roll so i dumped the clutch and it started up. got home turned it off tried to start it nothin.
battery is good, everything lights up when i turn the key radio etc.. No crank not even a click from the starter. I can hear the fuel pump kick on. checked all fuses in dash and hood.
kinda think its the Starter but i would @ least get a click or something from it.
thought maybe something like pick up coil or something but yet i would still get some sign from the starter.
thought it might be fuel shut off switch but fuel pump kicks on ( still going to check it in the morning )
im really thinkin its the CPP (clutch pedal postion) i think thats what it means in which the clutch has to be decompressed to start the truck. it seems to be that cause even with the truck in gear and u turn the key same thing wether the CPP was workin or not.
how to i check or fix the CPP also there is something about a sensor that has to make sure the tranny is in (N) cant MLP something like that.
thanks everyone
thanks everyone
