bulldawg1081
- May 30, 2013
- Automatic
I currently have 3.55's with a m5od and want to go with 31x10's. What's the ideal all around gear ratio for that size of tires with a 5spd?
I think 4.10's would be perfect myselfI use 4.10 with 31"x8.50x15" in my b-II. It was 3.45. That works good for me for combo street and offroad.
Richard
a 2.9 with 4.10's is about ideal, but I'd seriously consider slightly larger tires.
when I was still running a 2.9 I was already running 235/75-15's
when I switched to 4.10's.
Now that I have a 4.0 the 4.10's are just a bit "much" for long distance
highway cruising.
the 4.0 is an absolute pig when cruising above 2500rpm.
With my gears I get <2000rpm at 55mph in 5th, but I have a mazda trans
and thus a bit more overdrive than your A4LD
AD
