91 4.0 Wiring
rob864_0
Pasco, WA
Doing a swap, my donor is a 4.0 w/auto from an Explorer. Wiring diagram shows circuit 37 #10 Yellow. Where the #37 pin on Firewall connector is a #10 with light green insulation. Can I assume the pins and wire size are correct and the insulation is off?
Thanks in advance for your help.
Was planning on using that for my power to underdash fuse block.
Thanks, rob
What are you swapping it into? I can check later if I remember. My swap was '92 Explorer engine into an '87 Bronco II.
