- Jun 8, 2009
- Manual
Hi, I've found some good info on here regarding my Ranger so I thought I'd join up and see if I can get some advice regarding a potential Explorer purchase. I went back thru 6 pages of posts in the 4.0L section and saw several threads relating to the potential issue I'm looking at but wanted to run it by you guys to double check. One of my neighbors got laid off and wants to sell a '91 ExplorerXL 2dr 4x4 with the 4.0 and 5spd trans. It has 110,000 miles on it and he has owned it for about a year since purchasing it from the city. He let me take it home and drive it for the past couple days and the only issue I can come up with is that when you first start it up cold there is a constant loud TAP,TAP,TAP coming from the top of the engine that subsides after about 10 minutes of idling. Sometimes it will do it briefly after it's been driven and then parked for 30 minutes or so when you start it back up. I also noticed that occasionally while driving thru town at 35-45mph I will notice what sounds like the same noise but much quieter and in what I would call a rythmic or cyclic fasion like tap,tap,tap......tap,tap,tap......tap,tap,tap...He says it's been like that the whole time he's had it with no other problems. A friend suggested trying synthetic oil in it, so yesterday I put in some Valvoline SynPower 10w30 I had for my car and it seemed to make it louder so I drained that back out. I had a mechanic look at it today and he thinks it's the lifters bleeding down or something. I read some other posts here about maybe it could be pushrods or rockers? It sounds like it may be a common issue to these motors and I would like to know if this is something I will need to fix immediately or if it's a "they all do that, leave it alone" thing? The truck appears to have been very well maintained, including new factory radiator, alternator, and AC upgrade. There are no oil leaks on the engine block, not even any around the valve cover bolt areas which is a first for any Ford engine I've seen with any miles on it. So I really hate to have to crack open the engine if I don't have to. If the truck wasn't set up like I would have ordered it, 5sp, manual type 4x4, no pw/pdl, etc I would probably pass but I really like the truck and the $1500 price doesn't sound bad. Also is there a source for factory type replacement seatcovers? It's got the tan cloth 'striped' type and could use a new driver's seat cover. Many thanks for your suggestions and advice
