jss5891
- Aug 5, 2016
- Automatic
I have a 1991 Ranger 3.0 automatic .Just recently purchased. The issue i have is while driving it will sometimes randomly shut off and start back up on its on while still rolling. Only one time it actually shut off and would not crank back for a period of maybe 30 min. Sometimes it will run fine and sometime will have this random stumble and sometimes shut off.
The parts i have replaced trying to correct this so far are....
Fuel pump
Filter
Relay
Coil
Plugs & Wires
Cap and Rotor.
Pcv
I have checked all over for vacuum leaks and never found any.
The parts that looks new that the previous owner looks to have changed probably trying to fix this same issues are.
Mass air flow sensor
Idle air control valve.
I have see on line a lot of rangers have had this issue, but i have yet to find anyone who fixed it.
Any help would be much appreciated.
Thanks in advance
Fuel pump
Filter
Relay
Coil
Plugs & Wires
Cap and Rotor.
Pcv
Thanks in advance
