krunkpirate
- Jan 18, 2018
Greetings I have a intermittent starting issue and I'm not sure what to target first. It has happened twice now, but its not clear to me on the cause. When it happens there is a single audible click that seems to be the sound of the starter hitting something, but failing to crank. Misalignment with the flywheel? Anyways the first time it happened I had a co-worker attempt to help me jump it which seemed to fail, but after a few attempts it started up fine. I took it to an autozone and they tested the battery & alternator giving it a clean bill of health. I have driven it at least 30 or so times since then with no issues. This time around jumping it didn't have any success so I came back with a multimeter and was able to verify the battery was showing 12.24v. I attempted to bypass the solenoid on the upper wall of the passenger side by shorting the posts with a screwdriver. After that failed I attempted to tap the starter while having a co-worker attempt to crank. Same single click noise with no change. We decided to attempt a push start and after a partial success (seemed it was about to start, but failed) we tried to crank it and it started right up. I noted mild hesitation on the initial part of the drive home, but its an old truck with 500k+ miles so its hard to tell if this was really out of the norm. After arriving home I tried to turn it off and on about 10 times without a single issue.
A few questions I have outside of being open to any suggestions.
- Can a push start attempt effect a starter in a similar manner to the "tapping" method?
- Can a bad ground cause symptoms like this?
- If I decide to replace the starter does it have torque specs and are they critical for that replacement?
- Any general recommendations on repair manuals?
Background on whats been done in the 3 years I have owned this regret of a truck:
- Transmission was rebuilt by a shop.
- Fuel pump has been replaced.
- Shocks and front lower ball joints.
- Spark plugs and cables have been replace.
- O2 sensor replaced.
- Breaks and new e-brake cable.
- anti-lock break sensor replaced. (still doesn't work)
- Temp sensor replaced (still don't trust what the dash shows)
- Throttle position sensor replaced.
- Catalytic converter replaced.
I had issues with the 5th, reverse gear before the transmission rebuild. After that I had issues with engine hesitation, failing to stay on, poor idling that were intermittent. After throwing a lot of the parts listed above and regular fuel system cleaner treatments at it that went away. It also still pours out grey/white exhaust when I first take off, after it heats up its fine. That is a side item I need to figure out before emissions in june.
